Brenins Posted January 11, 2009 Posted January 11, 2009 Hello At present I have a hired alarm system (in Sweden) from Honeywell, the main central is a CMI8NE-SDI4G (with mobile as well as wired telephone connection) I will not renew the rental agreement when it ends soon, hence the CMI8NE-SDI4G will be returned to the company. All other Items such as one keypad (CSK8NE-SDI-, two smoke detectors (DTO600HF-, one PIR (IRX800HFCT- and one magnetic switch (DOD800HF- will stay as my property. I will like to buy a new main central and have found a CMI8UK-STD, will this be compatible with the items mentioned above, and can it all be programmed by using a TCU2-800 mobile keypad? Flemming Quote
Secware_Tech6 Posted January 20, 2009 Posted January 20, 2009 Yes it should but i would confirm the freq of the devices you have. SUpport Quote
Dowser Posted March 23, 2010 Posted March 23, 2010 Hi, How did it turn out for you? I'm another Swede with the exact same situation. But they did leave the CMI8NE-SDI4G unit here. Is it possible to buy a controller and "reset" the unit I have here or is the password-protection impossible to go around? Markus Quote
