Eddie-Secure2 Posted December 23, 2007 Posted December 23, 2007 I have a need to add 2 (ideally 3) door contacts onto a single zone on a texecom premier 48. I have tried putting resistors in each device but this wont work. I have looked in the manual and its not very detailed. It it possible or do i need to buy an expander such as the 8xe? Thanks Eddie Quote
Secware_Tech6 Posted December 24, 2007 Posted December 24, 2007 The best way is not to wire multiple devices per zone but dedicate each device to its own zone. Zones can then be 'grouped' into separate areas for part setting etc. But if required for double doors etc then see the attached diagram. Quote
