Amber Posted October 22, 2008 Posted October 22, 2008 I have a Cooper SD2+ connected to a system and working fine using the O2 SMS centre. I have been asked to switch this to using the BT Text service so that use can be made of the bundled free texts with the BT phone line. Not an unreasonable request. The problem is that I have tried almost every setting to get this unit to work with BT Text and have even had a BT engineering helping but to no avail. (message centre number 1470 P 17094009) Has anyone else found this to be a problem or managed to solve it? If so could you post the settings and procedure. Thanks Quote
Secware_Tech6 Posted October 22, 2008 Posted October 22, 2008 Amber I personaly have not tested any text unit on the bt message centre. I have checked with the manufacturer and neither have they as its designed to use the 02 message centre. Support Quote
