jonnyg2k5 Posted October 2, 2008 Share Posted October 2, 2008 I am currently installing an alarm/fire system in my home and have a few questions someone may kindly answer: 1. Does the Eurosec CPX have a built in dialer to call in the event of an alarm (so all I do is add a bt line) and if so does it tell you what the alarm is i.e zone, fire, intruder etc. 2. What type of cable should I use for the smoke heat detecors - normal alarm cable? 3. What smoke heat detecors are compatable with the Eurosec CPX? 4. The alarm unit will be mounted in a seperate room only accesable from outside (it's a outside utility room) although the utility room is secure would it be better to have the main unit within the house? 5. Finally, can you use the keyfobs with the Eurosec CPX and how do they work/what benefit are they? If you can answer any of the q's i would be greatfull..... Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted October 13, 2008 Share Posted October 13, 2008 1. Yes, and yes 2. Yes 3. Any of the double pole units, eg Menvier M12 4. Yes, and it should be in a protected area. 5. Yes you need a radio expander, and the benefit is you can arm etc from the fob Support Quote Link to comment Share on other sites More sharing options...
lee1 Posted January 23, 2009 Share Posted January 23, 2009 the eurosec cpx is a good panel 2 use.I would put the panel in the house eg loft, airing cupboard run the s.a.b outside and put the keypad somewhere easily axcesible get urself a wireless zone expander (risco) and u can put up 2 8 wireless zones on there including smoke detecters. very reliable wireless system and batterys last anything up to 2 years. the cpx has a built in speach dialler just connect the phone line turn the vocomm on and put ur numbers in (up 2 4) very easy when the alarm has an activation it will call u telling u which zone has been activated. hope my reply has helped u good luck!!! Quote Link to comment Share on other sites More sharing options...
