blackcat Posted August 12, 2008 Posted August 12, 2008 Hi I currently have a optima 8ep g3 system and i am looking to replace it with a more secure system. It is for a domestic install and needs to be wireless and deal with two cats. Reading the posts i am thinking about the system below: Galaxy 2-20 starter kit Eurosec Xs3d blue bell box live and xsd cover secware 4 way internal sounder honeywell domonial pet immune pir Am i on the right lines??? :-\ Quote
Secware_Tech6 Posted August 12, 2008 Posted August 12, 2008 Yes, those are compatible, but using wireless does limit you to that manufacturer. ie if you want to use say a bosch tri-tech or a crow etc. Wired gives more flexibilty of equipment.. but obviously needs wires. Support Quote
blackcat Posted August 15, 2008 Author Posted August 15, 2008 Hi Thanks for the prompt response. As i have access to floorboards and am able to chase into walls etc etc, which wired system would you recommend. Again it is to replace the existing system and needs to be pet friendly....... Quote
