  2. Some manufact do supply cases only. I'd have to find out tomorrow
  3. Hi Recently changed windows from Brown to White So does anyone know if I can buy white outers for the Sensors and Magnets above as the Brown ones will look really "odd" on white windows Many thanks jt
  4. Last week
  5. Did find this though Honeywell Galaxy Rs 232 Connection Help - Introduce Yourself - Security Installer Community (thesecurityinstaller.co.uk)
  6. I use an asix based one. Id have to check with honeywell if there is official recommendation but i wouldnt be hopefull, iirc they dont support serial over usb
  7. Earlier
  8. It just stays stuck at the connecting stage, then times out. Lights on the USB 232 kits flash after hitting connect, i guess form RSS tool requesting hand shake, then stop when it times out. I lowered rate below 9600, still no change. Same panel direct 232 on my older laptop (no USB) works fine. So am looking for a known working USB cable make please. Cheers John
  9. What USB to 232 cables are people using for G2 compatibility? It seems that my dimension USB cable will not play ball with the G2 panel. Works fine for dimension panels and associated 232 cable, just not the G2 panel and cable., Thanks John
  10. the issue here is the actual type of fire. An optical smoke detector can detect smoke and then a relay base will provide your relay for interconnection. However most are 12v you may need to use a power converter to drop to 12v dc from 24
  11. Hello, I'm hoping you can assist with a product enquiry. I'm looking for a device to detect the start of a lithium battery fire. I'm keen for advice on if heat and/or smoke is best for this use case. The power available is 24v DC and I'm hoping the sensor will have either a repay or some sort of output I can connect into a monitoring PLC. many thanks,
  12. Problem will be proving correct ownership etc. Can you contact where you got it from for the previous password?
  13. Hi, I've bought a second-hand Vista Viper HDAL 16, but I don't know the password - does anyone know how to reset please? Many thanks, Stuart.
    3.2k
    7.5k
    27,194
    donnywolf
    donnywolf
