CliveT joined the community
Yes, all wiring is fine. -
Andrea joined the community
will the nvr support 8mp?
Whats the best alternative for the obsolete L-TU-IP4M-VF-1 ? Aspect Lite 4MP IP Varifocal Lens Large Turret Camera [L-TU-IP4M-VF-1] - £100.50 : | Best Price Promise | Security Warehouse Professional products
No its a control panel and keypad only
Texecom Veritas R8 Plus Panel with LED Remote Keypad https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/texecom-veritas-r8-plus-panel-with-led-remote-keypad-p-323.html Does this item come with the necessary hardware to act as an autodialler
Andrewmot joined the community
examples Secware Double Flashing Battery Powered LED [SECWARE-DBFlash-LED] - £6.72 : | Best Price Promise | Security Warehouse Professional products HKC Decoy Flashing LED Unit [UKBPStrobe] - £18.70 : | Best Price Promise | Security Warehouse Professional products Bentley Double flash (unit with two LEDs) [AT-361] - £18.59 : | Best Price Promise | Security Warehouse Professional products They will last a couple of years. I have the Bentley one on a garage at home and it lasted 5 years so far.
Simon joined the community
Hi, Many thanks. That’s very helpful. Please could you let me know the links/references on your website for the LED kits … and a suitable decoy box to fit them. I presume that batteries for running the LEDs won’t need changing too frequently? Cheers, Simon
No not a mains powered one. There are battery led kits available but the only way to emulate a sounder is to use a real sounder and power it from a powersupply
Pre-Order Enquiry - Decoy Bell Box Do you sell a Decoy Burglar Alarm Bell Box that includes a mains powered light (such as a faint blue flashing strip light) that is always active ... and mimics an actual bell box. If so, please could you let me know the part number etc. If not, I would be very grateful for any suggestions ... such as modifying a standard decoy box? btw. Does 'Sigma' still exist or taken over? I installed a sigma system years ago and have tried to buy similar kit. Many thanks for your help.
It may well be but shock sensors still do latching but i dont know of a pir that supports it anymore. YOu may be able to find some new old stock. Installers dont do that anymore (for some time) as panels are bigger and its best practice to put everything on its own circuit. Walk test is to remotly disable/enable the led not latch
Total Topics7.7k
