  3. Eaton I-on 10-50 Zone Expandable control panel https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/110-input-zone-small-c-36_102_101/eaton-ion-1050-zone-expandable-control-panel-p-5752.html Will this work with radio smoke detectors? Is this compatible with manual fire alarm call points? And finally will this need some sort of relay box to work with a speech dialer? Thanks.
  4. Last week
  8. Earlier
  9. I am working on a project with one of our clients. We are installing Gallagher system for them - https://security.gallagher.com/. One of their requirements is to have wireless sensors on windows connected to the Gallagher system. I was told i could use this Wireless Receiver. But do you know which sensor i could use? For example we have Ajax sensors on hand. Do you have any experience with this type of setup? look forward hearing from you.
  26. Id look at the fike twinflex or better the addressable fike as this provides automatic hush in a HMO type environment Fike CIE-A-400 2 Loop Addressable Fire Alarm Control Panel [540-0001] - £631.41 : | Best Price Promise | Security Warehouse Professional products
  27. We are looking for a fully wireless, self install inturder system for our Gardeners Yard, we would need a few internal motion detectors and door contacts and some external gate contacts, we also would want some external sirens. We do have some power in the building for the base, but no internet and very little 4G signal., Is this something you can advise on?
  • Who's Online   1 Member, 0 Anonymous, 4 Guests (See full list)
    27,249
    Raymond1984
    Raymond1984
