Hi I have 2 zones, 4 pirs and 4 lights. Worked perfectly for years. Very recently all lights come on at dusk, even without movement. They then stay on permanently. I’ve changed the 1809 command centre. No joy. I’ve powered off and reset many times. Again, no joy. Any advice appreciated.
CliveT joined the community
Yes, all wiring is fine. -
Total Topics7.7k
Who's Online 0 Members, 0 Anonymous, 18 Guests (See full list)
