- Past hour
It sounds like you have either a failed controller or pir. DIsconnect all pirs andding one of them (test each one) and see if the fault disappears. If so start adding pirs back into the system until the fault reappears
Who's Online 1 Member, 0 Anonymous, 6 Guests (See full list)
