CliveT joined the community
Yes, all wiring is fine. -
Andrea joined the community
will the nvr support 8mp?
Whats the best alternative for the obsolete L-TU-IP4M-VF-1 ? Aspect Lite 4MP IP Varifocal Lens Large Turret Camera [L-TU-IP4M-VF-1] - £100.50 : | Best Price Promise | Security Warehouse Professional products
No its a control panel and keypad only
Texecom Veritas R8 Plus Panel with LED Remote Keypad https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/texecom-veritas-r8-plus-panel-with-led-remote-keypad-p-323.html Does this item come with the necessary hardware to act as an autodialler
Andrewmot joined the community
examples Secware Double Flashing Battery Powered LED [SECWARE-DBFlash-LED] - £6.72 : | Best Price Promise | Security Warehouse Professional products HKC Decoy Flashing LED Unit [UKBPStrobe] - £18.70 : | Best Price Promise | Security Warehouse Professional products Bentley Double flash (unit with two LEDs) [AT-361] - £18.59 : | Best Price Promise | Security Warehouse Professional products They will last a couple of years. I have the Bentley one on a garage at home and it lasted 5 years so far.
Simon joined the community
Hi, Many thanks. That’s very helpful. Please could you let me know the links/references on your website for the LED kits … and a suitable decoy box to fit them. I presume that batteries for running the LEDs won’t need changing too frequently? Cheers, Simon
Total Topics7.7k
Who's Online 0 Members, 0 Anonymous, 16 Guests (See full list)
