  2. I'm installing a Texecom Premier Elite system in my house. Looking at the Odyssey X sounders they all have the window for an alarm installer to put their logo. Would this look odd without one? After a some searching I found the Odyssey 5E. This looks better (no insert window!) but perhaps an older model? Are there other boxes that might be better for my DIY use case?
  3. Yesterday
  4. Hi I have 2 zones, 4 pirs and 4 lights. Worked perfectly for years. Very recently all lights come on at dusk, even without movement. They then stay on permanently. I’ve changed the 1809 command centre. No joy. I’ve powered off and reset many times. Again, no joy. Any advice appreciated.
  5. Last week
  6. can you tell me if the Flex 20 Mk7 can have a lan connection plugged directly in to the unit or do i need to go through a wall port connection? Thank you https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/1124-input-zone-medium-c-36_102_103/honeywell-flex-20-grade-2-20-zones-metal-box-mk7-p-5337.html
  7. The COM-ADPT-02 adapter board can be used to facilitate a COM-DATA-WIFI module on to older i-on30R and i-on40H panels, HOWEVER, the panels need a software version of at least V7.02.02 in order for the Wi-Fi module to be programmed.
  8. Will the COM-ADPT-02 allow the i-on30R control unit to adapt, to allow a com-data-wifi module to be added
  9. Earlier
  10. The current SD-LTE speech dialler maybe suitable . Eaton Universal 4G speech dialler [SD-LTE] - £240.00 : | Best Price Promise | Security Warehouse Professional products This is supplied / bundled in carton with a wired internal antenna (COM-ANT-01) There is the optional COM-ANT-02 suitable for installation externally to the buildings that can be ordered separately if required. Eaton COM-ANT-02 Comms Wifi Antenna For Com-Data Range [COM-ANT02] - £45.00 : | Best Price Promise | Security Warehouse Professional products The SD-LTE will require a micro SIM card that is enabled for Voice services provided by the installer or their customer., this uses the 3G / 4G network Installer or their customer can source their micro SIM from many suppliers and network operators If this is being fitted by a professional installer / electrician they may email into technical support for guides – although the SD-LTE has a basic manual included in the box. if you require further assistance, please do not hesitate to contact us.
  11. I have EATON SECURITY building alarm system …with Eaton Speech Dialer model TSD2-UK …however the telephone lines are now been replaced by digital phone via internet hub…so this will no longer operate. Could you please advise new EATON Speech Dialer using SIM card or other as a replacement…may need external aerial to increase range/ signal. Do you supply necessary SIM card ? If not who would your company recommend. Many thanks your support and advice is very welcome.
  12. We have a combined panel, so its a key pad and a fob reader, they are located inside at all 3 of our sites. Do you have a link or the name of the honeywell fob you were suggesting? Thanks
  13. Hi there, I am currently in the process of renovating a house and I am looking to install a fire detection system that not only meets building regulations for a three-story house but also offers higher protection than the minimum LD3 level. In the past, I have used a Honeywell Galaxy panel with fire zones, but that was a few years ago, and I am sure there have been advancements since then. I've been considering the C-Tec Hush Pro solution, but I'm concerned about nearing the 16-device limit. Running the cables around the house in a single run seems feasible, especially with the ceilings down and floors up, but I'm wondering if a larger 2-wire panel with a loop per floor might be a more practical option. Additionally, I'm curious if, like with the Hush solution, this can be achieved using 3-core + earth cables rather than FP cables. Alternatively, would an intruder alarm with fire zones still be a better option for a DIY setup? I would greatly appreciate any suggestions or recommendations you might have on what I could consider. It would be especially useful to have the option of using outputs for further home automation and remote app monitoring, as I have previously used Selfmon for similar purposes. Thank you in advance.
  14. I dont know of a manufacturer that supplies boards only. But may be available as a special order. Usually one would replace the whole sounder to keep it looking as new as spossible as this is the detterent
  15. Yes you will need a usb to serial converter. Or a PCI card supporting 232 serial
  16. You do enable / disable the circuits you want in each part set.
  17. the newer hkc micro rf sensors can be hidden if there is sufficient space. But will require a hkc panel
  18. Bosch or Honeywell are popular pro models
  19. Its should be 12v DC
  20. Any non addressable sab will be compatible. ie CQR
  21. I have a Reson8 bell box with an intermittent fault that I wish to replace. As I understand this is now an obsolete item, could someone advise the most suitable compatible replacement for the Optima Compact 8EP396 A panel. Thanks
  22. I have a question regarding the DUO-LINK II. What voltage supply should I be reading at the DC LINK OUT port on the viewer unit? I have got 48v DC IN present at the IN terminals on the Viewer.
  24. Hi, we have constructer a community hall with aluminium windows and doors. Do you have a door and window sensor which can be wired into the building security alarm or wireless which can be concealed in the frame? The Client does not like surface mounted door alarm sensors.
  25. Moved into a property a few years back and alarm works fine, however I want to alarm the garage alone so I thought maybe I could use Part Set programme 2 to do this. All went well until I tried to omit zones or even make them used or unused it worked quite well the first time but when I set it again all the zones have reverted to previous setting. I just want the garage zone active in programme 2. How can I make this permanent? I have tried in Engineers mode as well. Help would be appreciated. Cheers Clive
  26. American dynamics was the camera brand that I mentioned, but open to suggestions
  27. Can you please confirm if I can connect my euro 76 panel using R/S 232 loom to my PC Also do I need tobuy converter to USB as my pc does not have serial connections
  28. Have you confirmed all the wiring is OK?
  • Who's Online   0 Members, 0 Anonymous, 23 Guests (See full list)
    27,246
    a77711
    a77711
