  2. Moved into a property a few years back and alarm works fine, however I want to alarm the garage alone so I thought maybe I could use Part Set programme 2 to do this. All went well until I tried to omit zones or even make them used or unused it worked quite well the first time but when I set it again all the zones have reverted to previous setting. I just want the garage zone active in programme 2. How can I make this permanent? I have tried in Engineers mode as well. Help would be appreciated. Cheers Clive
  3. American dynamics was the camera brand that I mentioned, but open to suggestions
  4. Can you please confirm if I can connect my euro 76 panel using R/S 232 loom to my PC Also do I need tobuy converter to USB as my pc does not have serial connections
  5. Earlier
  6. Have you confirmed all the wiring is OK?
  7. The Scantronic Sounder External Wired Backplate, SDR-WEXT-G2, installed a few years ago worked perfectly until about a week ago, when I noticed that the 'comfort LEDs' had stopped working. On further investigation the unt does not sound the siren when an alarm condition is triggered, although the internal Scantronic 9651PD does. On opening the external sounder box its cover tamper switch does not trigger the external siren but again it does trigger the 9651PD. On further investigation, the internal battery of the external sounder is fully charged, therefore I suspect the sounder circuit board is faulty. Are replacement circuit boards available for this unit as I don't want to have to replace the whole external sounder box?
  8. Its a detector, would need to be part of a solution.
  9. Re the cctv do you have a preffered brand? Agree on the toy town stuff most budget equipment is exactly that. Alarm system wise again i dont know your expereience or preffered equipment?
  10. Takex Wireless Ready External Pet Tolerant 12m PIR Dual Head https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/wireless-ia-c-36_60/takex-wireless-ready-external-pet-tolerant-12m-pir-dual-head-p-2040.html Good morning, would this device be sufficient in deterring vagrants / rough sleepers?
  11. Hi I am a residential customer, looking for a CCTV system, American dynamics I am aware of. I have a commercial background so do not want something that is ‘toys are us’. Initially I want two external cameras, 360 degrees, night & day, zoom as discrete as possible. They need to be hard wired to the recorder, which can then be accessed by wi fi but not wi fi cameras if you catch my drift. Also is the facility available for sound recording? I.e if someone is standing outside a property shouting is it possible to capture real time video and sound recordings that could be used in legal proceedings ? In addition to this I will be wanting an alarm I have used Banham in the past, but not that impressed, again hard wired. Please could you let me know your thoughts ?
  12. A max reader us usually outside a door and is a reader only. A keyprox is a keypad and proximity reader combined
  13. That's great news, what product (fob) do you recommend? Whats keyprox & max?
  14. Yes if galaxy a honeywell or campatible fob will work on all. However there is a difference between keyprox and max
  15. Hi, We are a school with a primary, secondary & sixth form buildings, each with their own intruder alarm panel and we are looking for a fob which can be programmed to all 3 panels. I believe our panels are Honeywell Galaxy. Do you sell an alarm fob which can be programmed to multiple panels? I look forward to hearing from you.
  16. its going to need an engineer visit.i assume the system isnt serviced regularly?
  17. will the nvr support 8mp?
  18. I have a euro mimi house alarm system. Following a recent power cut the alarm will not accept my code. What do I need to input to reset the alarm system please
  19. Whats the best alternative for the obsolete L-TU-IP4M-VF-1 ? Aspect Lite 4MP IP Varifocal Lens Large Turret Camera [L-TU-IP4M-VF-1] - £100.50 : | Best Price Promise | Security Warehouse Professional products
  20. No its a control panel and keypad only
  21. Texecom Veritas R8 Plus Panel with LED Remote Keypad https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/texecom-veritas-r8-plus-panel-with-led-remote-keypad-p-323.html Does this item come with the necessary hardware to act as an autodialler
  22. examples Secware Double Flashing Battery Powered LED [SECWARE-DBFlash-LED] - £6.72 : | Best Price Promise | Security Warehouse Professional products HKC Decoy Flashing LED Unit [UKBPStrobe] - £18.70 : | Best Price Promise | Security Warehouse Professional products Bentley Double flash (unit with two LEDs) [AT-361] - £18.59 : | Best Price Promise | Security Warehouse Professional products They will last a couple of years. I have the Bentley one on a garage at home and it lasted 5 years so far.
  23. Hi, Many thanks. That’s very helpful. Please could you let me know the links/references on your website for the LED kits … and a suitable decoy box to fit them. I presume that batteries for running the LEDs won’t need changing too frequently? Cheers, Simon
  24. No not a mains powered one. There are battery led kits available but the only way to emulate a sounder is to use a real sounder and power it from a powersupply
  25. Pre-Order Enquiry - Decoy Bell Box Do you sell a Decoy Burglar Alarm Bell Box that includes a mains powered light (such as a faint blue flashing strip light) that is always active ... and mimics an actual bell box. If so, please could you let me know the part number etc. If not, I would be very grateful for any suggestions ... such as modifying a standard decoy box? btw. Does 'Sigma' still exist or taken over? I installed a sigma system years ago and have tried to buy similar kit. Many thanks for your help.
  26. It may well be but shock sensors still do latching but i dont know of a pir that supports it anymore. YOu may be able to find some new old stock. Installers dont do that anymore (for some time) as panels are bigger and its best practice to put everything on its own circuit. Walk test is to remotly disable/enable the led not latch
    7.7k
  • Who's Online   0 Members, 0 Anonymous, 20 Guests (See full list)
    27,241
    CliveT
    CliveT
