  2. Last week
  3. You can add a radio expander to this panel via the bus. Then compatible smoke detectors can be added. To use a call point you would need a clean switch model and add external eol resistors. A speech dialler can be directly connected to one of the programmable outputs. But this would not make it a complaint fire alarm. If BS5839 is required you will need to use a compliant fire alarm panel.
  4. Eaton I-on 10-50 Zone Expandable control panel https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/110-input-zone-small-c-36_102_101/eaton-ion-1050-zone-expandable-control-panel-p-5752.html Will this work with radio smoke detectors? Is this compatible with manual fire alarm call points? And finally will this need some sort of relay box to work with a speech dialer? Thanks.
  5. Earlier
  6. Omitting Zones Your system may be programmed so that you can omit individual detectors. Ask your Installer which zones can be omitted. To omit a zone: 1. Key in your access code or present a tag and press X. The display shows: Omit Zone? 2. Press the number of the zone you want to omit (for example, key in 07 to omit zone 7). 3. Press Y. The sounder gives a double beep and the display shows the zone number followed by an "o": Note: Omit Zone? Omit Zone 07o If the display shows a “x” after the zone number then you cannot omit that zone. To omit further zones repeat steps 2 and 3. 4. Press X to finish. To set the system with an omitted zone: 5. Key in your access code (or present a tag) and press a Level key.. 6. The control unit gives an error tone and the display shows (for example): A:Omit Zone 07? 7. Press Y. If necessary, press Y again for each omitted zone shown on the display. (If you wish to escape press X.) After you press Y for the final omitted zone the control unit starts to set.
  7. Hi how do I omit a zone on key a control pad 9651 /9941?
  8. What wireless rx are you using. I assume this is then connected to the panel hard wired?
  9. I am working on a project with one of our clients. We are installing Gallagher system for them - https://security.gallagher.com/. One of their requirements is to have wireless sensors on windows connected to the Gallagher system. I was told i could use this Wireless Receiver. But do you know which sensor i could use? For example we have Ajax sensors on hand. Do you have any experience with this type of setup? look forward hearing from you.
  26. Id look at the fike twinflex or better the addressable fike as this provides automatic hush in a HMO type environment Fike CIE-A-400 2 Loop Addressable Fire Alarm Control Panel [540-0001] - £631.41 : | Best Price Promise | Security Warehouse Professional products
  27. We are looking for a fully wireless, self install inturder system for our Gardeners Yard, we would need a few internal motion detectors and door contacts and some external gate contacts, we also would want some external sirens. We do have some power in the building for the base, but no internet and very little 4G signal., Is this something you can advise on?
  • Who's Online   0 Members, 0 Anonymous, 10 Guests (See full list)
