  2. Omitting Zones Your system may be programmed so that you can omit individual detectors. Ask your Installer which zones can be omitted. To omit a zone: 1. Key in your access code or present a tag and press X. The display shows: Omit Zone? 2. Press the number of the zone you want to omit (for example, key in 07 to omit zone 7). 3. Press Y. The sounder gives a double beep and the display shows the zone number followed by an "o": Note: Omit Zone? Omit Zone 07o If the display shows a “x” after the zone number then you cannot omit that zone. To omit further zones repeat steps 2 and 3. 4. Press X to finish. To set the system with an omitted zone: 5. Key in your access code (or present a tag) and press a Level key.. 6. The control unit gives an error tone and the display shows (for example): A:Omit Zone 07? 7. Press Y. If necessary, press Y again for each omitted zone shown on the display. (If you wish to escape press X.) After you press Y for the final omitted zone the control unit starts to set.
  3. Hi how do I omit a zone on key a control pad 9651 /9941?
  4. What wireless rx are you using. I assume this is then connected to the panel hard wired?
  5. I am working on a project with one of our clients. We are installing Gallagher system for them - https://security.gallagher.com/. One of their requirements is to have wireless sensors on windows connected to the Gallagher system. I was told i could use this Wireless Receiver. But do you know which sensor i could use? For example we have Ajax sensors on hand. Do you have any experience with this type of setup? look forward hearing from you.
  6. Last week
  7. Hi Solar powered cameras are usually diy type products and not professional grade. There are solar options but due to the size and cost and usually specialised. Plus you will need to run some sort of wifi transmitter as well as the camera. You will also need to consider the time the camera and any ir emitter will have to function during hours of darkeness and low recharge output in the winter,
  8. Hi, I am looking for a 2 or 3 camera system for continuous recording, web access (via a phone app I assume?), and at least 1 solar powered wireless camera. Can you help?
  9. Earlier
  10. Alarm battery calculator tool Free Alarm battery size calculator
  11. The aritech se sirs require either a compatible panel or an analyser. You may be better off with a knight combined unit
  12. As above converters are not designed or tested for this purpose. It may work 80% of the time but may not when actually needed. You need a communicator designed for ip or gsm
  13. Unfortunately we cannot confirm this, as it has not been tested by us. There are many telephone adapters and routers themselves, that can simulate PSTN lines, however , there is no guarantee our PSTN products, including the SD1+, will function correctly, as they were never designed to work on this type of arrangement/digital line. You should also be aware that the SD1+ is obsolete and have been replaced by the SD-LTE; Eaton Universal 4G speech dialler [SD-LTE] - £240.00 : | Best Price Promise | Security Warehouse Professional products Kind Regards, Security Warehouse Technical Support
  14. Will my SD1+ still work when BT goes digital?
  15. Having some frenchdoors replaced but the old sensor broke so can this sensor also be wired to my existing alarm system Veritas system Aritech GS612 Shock Sensor https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/misc-detectors-c-36_84/aritech-gs612-shock-sensor-p-3509.html
  16. Yes you will need a compatible lock case to suit the door type
  17. I want to specify a Paxton Pro Standalone unit for a FD60 exit door. What lock should i specify for best compatibility? Do you supply a mortice latch/lock/lever unit that works with it?
  18. You can use either the HKC with standalone contacts in enclosures eith HD external contacts or the pyronix enforcer. Both will function without internet but notifications wont be possible, Note our products are designed for professional installer use
  19. what you need is a shunt lock. Different lock types are available for different doors, backsets etc
  20. Any hard wired bell would be suitable. We do offer SW bell stickers to add to the unit
  21. It sounds like you have either a failed controller or pir. DIsconnect all pirs andding one of them (test each one) and see if the fault disappears. If so start adding pirs back into the system until the fault reappears
  22. The panel will require an ethernet module and then the ethernet cable can be plugged in
  23. Honeywell Galaxy ASK Keyprox Proximity FOB [YXO-0020] - £5.39 : | Best Price Promise | Security Warehouse Professional products honeywell fob. there are also honeywell compatible available
  24. Id look at the fike twinflex or better the addressable fike as this provides automatic hush in a HMO type environment Fike CIE-A-400 2 Loop Addressable Fire Alarm Control Panel [540-0001] - £631.41 : | Best Price Promise | Security Warehouse Professional products
  25. We are looking for a fully wireless, self install inturder system for our Gardeners Yard, we would need a few internal motion detectors and door contacts and some external gate contacts, we also would want some external sirens. We do have some power in the building for the base, but no internet and very little 4G signal., Is this something you can advise on?
  26. MDT Avanti LC Steel Control Panel https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/control-panels-all-c-36_102_41/mdt-avanti-lc-steel-control-panel-p-1000.html Hi, can this unit ( Avanti LC 9EP309 ) replace an old ( Avanti XP PLUS Steel Panel unit - Product Code - 9EP322).
  27. Good morning I wondered if you could help, we have fitted a ali door to a business which has a Chubb alarm system, and the Chubb engineer has said the below. "The lock or keep needs to have an integral micro switch contact on it to provide electrical connections. Giving common, normally open and normally closed options for the connection onto the alarm" I could really use some help with this from someone who knows, I do have pictures of the door if i can send them across to you. Wondered if you had i stock or could get what i need, Thank you
  • Who's Online   0 Members, 0 Anonymous, 107 Guests (See full list)
    27,249
    Raymond1984
    Raymond1984
