cjp64 Posted May 12, 2008 Posted May 12, 2008 I have a 10 year old Veritas R8 Plus Control Panel. I would like to add a Veritas Excel RKP (the one with the LCD display). I can see from the Texecom website that the two should be compatible. My question is whether the RKP will be compatible with a control panel which is as old as mine (ie I am worried that there has been a software update or some other change made since my panel went into service which is needed to control the Veritas Excel RKP). Thanks for your help. Chris Quote
Select Security Systems Posted September 1, 2008 Posted September 1, 2008 Will be fine, the panel will have had some software updates, but this will not effect the function of the RKP Quote
