securitywarehouse Posted July 26, 2010 Posted July 26, 2010 i have respond/eclipse wireless system fitted in the house occasionally i have my van in the driveway would this "Risco Wisdom Wireless Shock Detector" be suitable to fit in the van? or can you recomend one that woud work with my alarm Quote
Specialist1 Posted July 26, 2010 Posted July 26, 2010 Have to be honest I would'nt fit a shock detector in your van, with all the banging about it's going to get in normal everyday use it probably would'nt last very long & shocks don't respond well to being bounced about. Andy @ Amman Security Quote
securitywarehouse Posted July 26, 2010 Author Posted July 26, 2010 Hi as it is wireless alarm I would only place the shock detector in the van when I had van at home overnight fitting as required and leaving shock detector at home until required again Quote
Specialist1 Posted July 26, 2010 Posted July 26, 2010 Hi: How are you going to attach the sensor? for a shock det to work properly it has to be securely attached to a firm surface, it can't just be put in place. Andy @ Amman Security Quote
