July 21, 201016 yr Does this come with a battery ?? If not, which one do I need to order for it. Which Remote keypad do I need to order for it.
July 24, 201016 yr Hi: The Remote keypad for this panel is listed as the 9427 & a Secware 2.3 amp hour battery should do you nicely. Hope that helps: Andy @ Amman Security
