securitywarehouse Posted June 28, 2010 Share Posted June 28, 2010 I require a flush door contact to be fitted to a wooden door. Can you please recommend a product? As I am confused by the terms \\\'Grade 3\\\' \\\'Grade 2\\\' and \\\'Green Resistor\\\' \\\'Red Resistor\\\' I will be purchasing the Scantronic 9651 (not sure if that makes a difference) Quote Link to comment Share on other sites More sharing options...
FastCar Posted June 28, 2010 Share Posted June 28, 2010 If you are using the standard wiring option ( CCL or Closed Circuit Loop ) , then use SECWARE A40 5 Terminal Flush Contact , also available in brown. Quote Link to comment Share on other sites More sharing options...
shailezh Posted June 28, 2010 Share Posted June 28, 2010 Thanks. I take it the alarm cable will screw straight into one side of the contact terminal? Quote Link to comment Share on other sites More sharing options...
FastCar Posted June 28, 2010 Share Posted June 28, 2010 Yes , the cable connects to the screw terminals. Quote Link to comment Share on other sites More sharing options...
