June 18, 201016 yr we would like to fit a wired Alarm system, we have made the following list of items We like the look of the scantronic 9941 box as we would like to put a TSD2 speech dialler on so that we can telephone and check the system remotely. > > We would then like to put a remote keypad in the porch area at the front of the house which we would like to have night set options. We would also like to have a personal attack button and maybe a keyfob to de activate the system. We would like an internal sounder but maybe this is built in to the system. > > We would like a siren and strobe sounder on the front of the building. > > Detection Points > > Front door concealed magnetic contact / final exit > > Dining room integrated quad passive infa red & microwave technology PIR > > Lounge integrated quad passive infa red & microwave technology PIR > > Family room integrated quad passive infa red & microwave technology PIR > > Kitchen integrated quad passive infa red & microwave technology PIR > > Study standard quad passive infa red PIR > > Utility Room (has obscured glazed door to side passage) not sure whether PIR or door detector is better > > Main bedroom intelligent quad passive infa red PIR > 24 hr personal attack button > > Landing standard quad passive infa red PIR > Garage up & over door heavy duty magnetic reed contact > > Garage side door opening onto path down side of house surface magnetic reed contact > > > > > Perhaps you can advise us further and put together a list of all the components we will need. I do not understand the difference between all the PIR\'s suggested so perhaps you can help. It was suggested that the bedroom and landing PIR have a night set function which I assume means that all the others remain active but these are inactive during the night. I am hoping as said above that the control box can be hidden away but maybe you could suggest the location of the speech dialler. thanks for your help.
June 28, 201016 yr Hi , the 9941 you mention is actually a keypad that can be used on a number of different Scantronic panels.You also list 12 zones approx. so this rules out the 9651 (most domestic panels have 8 zones as standard ).You should also look at the Texecom Premier range and the Galaxy 2-20.These panels are not really intended as DIY install .A good quad detector (in my opinion) is sufficient in a domestic property.Your list looks like a rough quote..try another company.
