[Ticket Question] Are these products compatible?
Hi, I am about to purchase the items in my Checkout Basket and would like confirmation that the chosen items are all compatable with each other. Also I require a dummy LED to go with the dummy backplate and cover, can you advice if you have this item for the Texecom ODYSSEY 3.
I also require info on which backup battery is required and fits in the control panel I have chosen.
The following items are in my Checkout Basket:
1off- Scantronic 9651EN-43 (9651 c/w 9943rkp)
6off- Bosch Blueline ISM-BLP1 PIR Detectors
1off- CQR SOINT1 internal sounder
1off- Texecom ODYSSEY 3E Live Backplate
1off- Texecom ODYSSEY 3 Dummy Backplate
2off- Texecom ODYSSEY 3 covers
1off- Scantronic PROX-TAG
Dummy Box LED....???
Backup Battery...???
Hi
I can confirm that all of the items you have chosen are compatible with each other and the back up battery that we would recommend would be the Yuasa 7ah.
You can purchase two types of LED.  One with flying leads and the other with a battery.  Sadly the Ody 3 dummy does not have a place for you to mount them.  If you wish to purchase the Ody 3 and would like the live & dummy to be identical to look at you may consider purchasing two Ody 3E rather than one live and 1 dummy.
Hope this information helps you.
