May 20, 201016 yr Hi Have installed this Powermax plus quick fit , all is working but it comes up with a trouble fault of Tamper open on Zone 30. This Zone is not used and the resistors are crossing the Z29 GND and Z30GND , could you advise how to resolve this? The panel is arming
May 20, 201016 yr Swop the resistors over , see if the fault moves , if so , the resistor is out of range.
