When trying to leave engineer mode keypad says:
CHECKING FOR TAMPERS
1 mod tampers
KEYPAD 010
So I can´t leave engineer mode.
There is no battery installed in central panel.
Connection is: RIO (nothing connected yet) - Central Panel - Keypad MK8 - RIO (with 1 detector)
1. What is wrong?
2. Maual says 10 Ah and 17 Ah battery. Is it ok tu usa a 7 Ah battery?
I removed RIO with detector, so Keypad MK8 became in the end of the daisy chain.
The keypad error disappeared.
But I think it was the tamper in the keypad that was the fault.
Or must the keypad be in the end of the daisy chain?
Now there is a power fault, so I better get a battery.
The keypad can be anywhere in the chain.  It's most likely that the keypad is/was not closed properly and tamper switch on the PCB is not being closed.
Battery requirements are based on system loading. You'll likely be fine with a 7ah battery if your system doesn't have lots of powered devices.
