November 4, 201411 yr My old security light control box (Racal Guardall RLC1) has packed up after many years of use. It appears this Company no longer exists so I contacted Security Warehouse for advice. They told me that if it is a single zone system (I have 6 lights and four PIRs outside) I will need a GJD005 Sapphire Mk3 control box. I duly bought one. However, when I eventually got an electrician to call he told me the wiring wasn't compatible as the old control box only had one output feed and the new one has more. As I know next to nothing about this issue, is there anyone who can give me advice and if so, in simple terms please?
November 6, 201411 yr i doubt the existing sensors will work with a gjd controller but there should be as a minimum a 4 core lv cable going to existing detectors. gjd detectors need 4 cores (power, detection and light level signals) to function. do you / did you have a multi controller system?
