[Ticket Question] Help with a Eurosec CP8L LCD
securitywarehouse
I have a Eurosec CP8L LCD. This has been very reliable.
However I have had a new front door fitted which meant using a new surface mounted reed sensor for my entry/Exit contact wired in series with my back door sensor.
I want to check my zone settings.
I want to reset my entry time to 30secs, unfortunately I am unable to programme the zones, the display just keeps going back to "do you want to Program Chime" and will not allow me to proceed further to Program Zones.
Have you any idea how I can get to the program zones.
I have done a factory reset, ie:- disconnected the power, etc but to no avail.
Have I pressed something I shouldn't have?
I have had this unit for a few years now and it has served me well, so I would appreciate any help to get is sorted.
Link to comment
Share on other sites
You will need the installing engineers code , this is used to program all the different settings of the system.If you do not have it , then the system will have to be defaulted back to factory settings , BUT there is a chance the code could have been locked, meaning you can do no programming.
Link to comment
