The hint is in the title  ;) :
"Viper GLX SENSOR WHITE GRADE 3"
As far as grades are concerned, please look up the European standard for all the definitions.
EN50131 European Standards For Intruder Alarm Systems
Grade 3 is for a reasonably substantial risk property. There is good reason to assume it may be broken into and might well contain objects of high value. An intruder is likely to gain access by penetrating doors, windows or other openings. The thief could be very experienced with intruder alarm systems and possess a number of tools and equipment to overcome the system
Cheers,
