We're about to install an Accenta Mini Gen4 with conventional intruder detectors, remote keypads and an external bell sounder. We will also have a number of Menvier M12 smoke detectors on Zones 7 & 8 for 24-hour fire detection.
If Zones 7 & 8 trigger, we're expecting the Accenta to display an appropriate alarm on the RKPs and do 2-sec on / 2-sec off signalling on the external bell box.
If possible, we also wish to fit an all-in-one sounder / strobe unit in a specific room to ensure that the occupants understand that the "bells that they can hear ringing in the distance" are indicating a fire alarm (and that they should evacuate). We're uncertain if something like the EPS Fireline Combined Banshee Sounder & Strobe could be successfully used in this configuration or whether we're stuck with just attaching a 16ohm speaker to the Accenta's Extension Speaker output (with no strobe).
What unit(s) would you recommend to meet our requirements - bearing in the mind the available outputs on the Accenta? Also, any guidance on wiring?
