securitywarehouse Posted November 29, 2010 Posted November 29, 2010 hi i have just installed this panel to an exsisting system, it has 1 door entry contact and 2 pirs 1 on the route to the panel the other at the back of the house. i conected the door contact to zone 1 the pir on route to the panel on zone2 and the other to zone 3 i am using program 1 and set zone 2 as timed inhibit the problem im having is when i do a walk test zone 1 triggers zone 3 and visa versa zone 2 triggers on its own fine. so if i set the alarm as i trigger the door contact (zone 1)before i get to the panel the alarm activates so i enter the code to silence and zone 1 & 2 are solid and 3 is flashing the door contact is only 2 wir so i cant have wired it up wrong any idea what i have done wrong? Quote
