securitywarehouse Posted November 2, 2010 Share Posted November 2, 2010 Having just been burgled I have purchased a KX15DATM pir from you to replace a failing unit from a different manufacturer. The existing unit is connected via 6 cables - 2x Tamper, 2x Relay and 2x 12v. Do you know what connectors the cables need to be screwed into on the KX15 please? I may also have to change some of the dip switches? The control panel is an Accenta 8. Quote Link to comment Share on other sites More sharing options...
FastCar Posted November 2, 2010 Share Posted November 2, 2010 Make a note of how the existing pir is wired ( or take a picture) there will be a colour code used by the installer eg. RED / BLACK for power , YELLOW BLUE for alarm etc. just copy those over to the new detector , careful you do not touch any wires together as you may blow a fuse in the panel.Refere to the instructions that came with the new pir , your dip switched should be set to CC (closed circuit) or similar. Quote Link to comment Share on other sites More sharing options...
