securitywarehouse Posted October 14, 2010 Share Posted October 14, 2010 could you tell me if the system uses 12 volts as a battery backup ? i am looking to putting this system into 4 garages/lock ups where there s no mains power, but i could use 12v batterys if this system runs on 12v when no mains power avalable, also is it a 12v supply that activates the siren, thank you. Quote Link to comment Share on other sites More sharing options...
FastCar Posted October 14, 2010 Share Posted October 14, 2010 Most domestic alarm systems use 12v batteries for operation during mains fail , these usually keep the system functioning for approx 8 hours depending on battery size.Some systems will not set with a mains failed.If you have no mains supply , look for a system that is designed for battery only operation.Try typing "void property alarm " into google ,that will give you a better idea. Quote Link to comment Share on other sites More sharing options...
