stevehollister Posted September 17, 2010 Share Posted September 17, 2010 Hi A friend of mine has bought a shop with a g3 alarm panel. Nobody knows the codes to use the alarm. I have tried various engineer codes but none work. Is there a way round this or is it a new main panel job. Thanks Quote Link to comment Share on other sites More sharing options...
FastCar Posted September 18, 2010 Share Posted September 18, 2010 You will require the engineers manual ( search the web , its readily available), it shows you how to default the panel to its " factory state" , resetting the codes to default , and also how to reprogram it to your requirements. Quote Link to comment Share on other sites More sharing options...
