[Ticket Question] Help with a replacement keypad for a Eurosec
securitywarehouse
I have a client who has an existing alarm system with a eurosec keypad, PR5208 rev 1.0.
The keys 2 & 5 have given up working, so we need to replace just the keypad. Is the "Risco Gardtec Eurosec LCD Keypad" product that you sell the right one, or do i need the other one you sell that is for CPX and GTag?
Also the original company to fit the system are no longer around, would you have a copy of the installer manual with the default master/installer code as i quite expect that taking the old pad off the wall will set off the system and as the buttons dont work i'll need to reset it all.
If the panel you currently have is the CP8L as below ...
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=697
then the replacement key pad for this panel is the Risco Gardtec Eurosec LCD Keypad, see the link below ...
http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&products_id=580
Hope this information helps ;)
