  2. Knight Grade 2 Shock and Surface / Tilt Sensor [SEISMO] - £18.69 : , Best Price Promise is a suitable shock sensor Elmdene 12V DC 1A PSU [G13801N-A] - £23.66 : , Best Price Promise 12v 1A power supply Enersys 12v 3.4Ah Battery [Enersys12v3.4] - £11.47 : , Best Price Promise battery Interface Solutions 12 volt Polarised Relay [IS12] - £8.50 : , Best Price Promise relay to provide 2 sets of volt free contacts from the detector. Without knowing exactly what your wanting to achieve the above would function, but probably better to connect the shock sensor to its own intruder panel and link the output of the panel to the BMS
  3. additionally, we would need the device to have the following:- Powered by a dc supply with battery backup in case the power supply fail's Alarm contact for a sounder. Volt free contact for BMS so we can link to our security system. Information as to how the device is set before we close the cage and how it is reset, is there a short delay on setting the alarm? Can you suggest what we could use? Many Thanks
  4. The Risco Shocktec maybe an option a shock detector to use on your metal cage. I have added the link to our website for pricing; Risco ShockTec Plus with Grade 3 Contact [RK601SMG3] - £21.64 : , Best Price Promise
  5. Can you suggest a shock detector to use on a metal cage.
  6. Earlier
  7. jameswilson2 joined the community
  8. A pro IP camera could do this but wifi based camera are not usually pro level. This would enable an app on a phone with smart push notifications.
  9. Yes please, I would like an alternative that has a built in buzzer or chime(not a loud siren). Also it must not need to connect to wifi as looking for a basic standalone device. Thank you.
  10. The sensor will not work through glass, as the glass blocks the infrared needed for it to detect movement. It would need to be positioned with a clear, unobstructed view to operate correctly. If you’d like help finding an alternative that will suit your setup, I’m happy to assist.
  11. I am looking for motion sensors that sit on my window cill that points out of window and can detect a person outside but only up to a few meters. I would like a buzzer that goes off but not a loud siren. I dont have Wifi for security risks as everything is multiple VLANs via ethernet cables. Can you please recommend what would be suitable to achieve this, Thank you
  12. Hi I am looking for a direct replacement for an old outdoor doom camera . It's and eneo edc-141e, any ideas?
  13. If you r panel has a built in ethernet port you can connect it to the router. Then setup the app and or signalling etc
  14. No you will need to replace the panel. The Optima accenta range is long obsolete
  15. I have a few G3 Keypads as they are now Obolete can you upgrade with a latter model or do you have to change the pannel also?
  16. Hi, How do I connect my I on 40 security system to the internet?
  17. Optex and take make the best or beams imo Panel wise it depends on the features you need?
  18. Optex 20m External Twin Beam https://www.securitywarehouse.co.uk/catalog/cctv-equipment-c-1/detection-c-1_24/optex-20m-external-twin-beam-p-84.html Hi there, I am looking to have this type of system used in my house. To cover all usual access’s. Could you advise what infrared systems would be best and what control panel to streamline them with?
  19. yes or Eaton M12 multi sensor smoke and heat detector
  20. That detector requires an analysed circuit on the panel (some panels support this) or an analyser. Alternativly is a conventional circuit use Knight Grade 2 Shock and Surface / Tilt Sensor [SEISMO]
  21. ESP Optical Smoke Detector 12V With Relay Base PSD-212 https://www.securitywarehouse.co.uk/catalog/fire-c-38/firesmoke-detectors-c-38_39/esp-optical-smoke-detector-12v-with-relay-base-psd212-p-5303.html Will this fit an accenta g4 alarm panel. Four connections positive negative two more wires for trigger to zone 8.
  22. https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/vibration-detectors-c-36_56/aritech-gs610-shock-sensor-p-2831.html I have a wired home alarm system. Looking for replacements sensors that detect any force used to gain entry at windows (maybe referred to as shock sensors) Would this product be suitable?
  23. yes probably, what sensor are you replacing and in what environment?
  24. would this be a suitable quality replacement for a failed pir on my OPTIMA XM6 home alarm box Bosch Blue Line Gen2 12m PIR Detector https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/movement-detectors-c-36_116/all-c-36_116_37/bosch-blue-line-gen2-12m-pir-detector-p-2291.html
  25. Texecom Connect App – Free to Download The Texecom Connect app is free to install and use. However, to unlock its full functionality, your alarm system must be compatible and properly configured. For remote access and control, a Texecom SmartCom or SmartCom 4G module may be required, depending on your setup. Texecom Connect
  26. Generally a beeping texecom alarm is caused by 2 things. Chime is enabled and it is beeping when a circuit activates or it has a fault. Texecom Turn Chime Off Press the musical note button on the keypad. The chime will be disabled immediately. To set up chime zones: Enter your 4-digit user code. Press MENU, then press TICK to confirm. Scroll through the menu and select Edit Chime Zones. Press TICK. Browse the zone list and highlight the zone you want to enable. Press X to toggle. The zone status will change from Silent to Chime. Press MENU, then RESET to save and exit. Diagnose A Texecom System Fault If it’s a system fault that’s causing the beeping, your keypad will show a fault message. The beep will continue until the fault is fixed. Make a note of the fault displayed, this can also be retrieved from the texecom panel log Try entering your 4 digit code, then RESET. For further assistance create a new topic in the support forum listing the equipment type and fault reported.
  • Total Posts 7.8k
  • 27,251 Total Members
