yes or Eaton M12 multi sensor smoke and heat detector - Earlier
Hi Solar powered cameras are usually diy type products and not professional grade. There are solar options but due to the size and cost and usually specialised. Plus you will need to run some sort of wifi transmitter as well as the camera. You will also need to consider the time the camera and any ir emitter will have to function during hours of darkeness and low recharge output in the winter,
Who's Online 0 Members, 0 Anonymous, 8 Guests (See full list)
