  2. I have a few G3 Keypads as they are now Obolete can you upgrade with a latter model or do you have to change the pannel also?
  3. Earlier
  4. Hi, How do I connect my I on 40 security system to the internet?
  5. Optex and take make the best or beams imo Panel wise it depends on the features you need?
  6. Optex 20m External Twin Beam https://www.securitywarehouse.co.uk/catalog/cctv-equipment-c-1/detection-c-1_24/optex-20m-external-twin-beam-p-84.html Hi there, I am looking to have this type of system used in my house. To cover all usual access’s. Could you advise what infrared systems would be best and what control panel to streamline them with?
  7. yes or Eaton M12 multi sensor smoke and heat detector
  8. That detector requires an analysed circuit on the panel (some panels support this) or an analyser. Alternativly is a conventional circuit use Knight Grade 2 Shock and Surface / Tilt Sensor [SEISMO]
  9. ESP Optical Smoke Detector 12V With Relay Base PSD-212 https://www.securitywarehouse.co.uk/catalog/fire-c-38/firesmoke-detectors-c-38_39/esp-optical-smoke-detector-12v-with-relay-base-psd212-p-5303.html Will this fit an accenta g4 alarm panel. Four connections positive negative two more wires for trigger to zone 8.
  10. https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/vibration-detectors-c-36_56/aritech-gs610-shock-sensor-p-2831.html I have a wired home alarm system. Looking for replacements sensors that detect any force used to gain entry at windows (maybe referred to as shock sensors) Would this product be suitable?
  11. yes probably, what sensor are you replacing and in what environment?
  12. would this be a suitable quality replacement for a failed pir on my OPTIMA XM6 home alarm box Bosch Blue Line Gen2 12m PIR Detector https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/movement-detectors-c-36_116/all-c-36_116_37/bosch-blue-line-gen2-12m-pir-detector-p-2291.html
  13. Texecom Connect App – Free to Download The Texecom Connect app is free to install and use. However, to unlock its full functionality, your alarm system must be compatible and properly configured. For remote access and control, a Texecom SmartCom or SmartCom 4G module may be required, depending on your setup. Texecom Connect
  14. Generally a beeping texecom alarm is caused by 2 things. Chime is enabled and it is beeping when a circuit activates or it has a fault. Texecom Turn Chime Off Press the musical note button on the keypad. The chime will be disabled immediately. To set up chime zones: Enter your 4-digit user code. Press MENU, then press TICK to confirm. Scroll through the menu and select Edit Chime Zones. Press TICK. Browse the zone list and highlight the zone you want to enable. Press X to toggle. The zone status will change from Silent to Chime. Press MENU, then RESET to save and exit. Diagnose A Texecom System Fault If it’s a system fault that’s causing the beeping, your keypad will show a fault message. The beep will continue until the fault is fixed. Make a note of the fault displayed, this can also be retrieved from the texecom panel log Try entering your 4 digit code, then RESET. For further assistance create a new topic in the support forum listing the equipment type and fault reported.
  15. The default user code for texecom systems is '4321' but it may have been changed.
  16. Due to the chnage of elevation (ie top and bottom of stairs your really going to need 2 sensors. A corridor sensor on a bracket may work well but isnt designed to angled that way. Also bear in mind the link you provided is a intruder alarm sensor not for switching 240v. It could be connected to a relay and suitable power source though. If doing that id recommend a voltek system as they provide adjustable low voltage sensors and it will be easier to run a low voltage alarm cable to the sensors from where the current switching is taking place. Voltek single head adjutable PIR
  17. Please see attached images of our set-up. You can see in the white circle that the PIR fitting is located above the main door on the ground floor. Currently, it only activates when someone reaches the 4th step (both going up and down the stairs). We need the PIR sensor to: Activate the lights when someone walks through the main door on the ground floor. Also activate when someone is coming down the stairs from the 1st floor. The distance from the ground floor to the 1st floor is approximately 9 metres, but with an incline. Please could you advise on a suitable solution, or confirm whether the link provided above would work for this setup? Many thanks,
  18. secware3
  19. Yes images would be useful to get a better understanding. ALso a drawing where you want detector coverage? You can upload them here
  20. I’m looking for a PIR sensor that can detect movement both from the bottom and the top of a staircase. Our current sensor is positioned on the wall above the door at the bottom of the staircase, but it only detects movement when someone is about four steps from the bottom. This is creating a safety risk, as the lights aren’t activating until a person walking down is already quite close to the bottom. The staircase is approximately 9 metres long. I have images I can share — please let me know an email address where I can send them. I was looking at the following item and was wondering if it would work for my requirements, or if you could recommend a product that would be more suitable for my situation. Thank you! https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/movement-detectors-c-36_116/all-c-36_116_37/optex-cx702-21m-wide-or-45m-long-pir-p-157.html
  21. There is no real difference between an intruder alarm and a burglar alarm. A burglar alarm is often the phase that is used to describe an intruder alarm but intruder alarm is the more accurate term as not all unwanted intruders are burglars.
  22. There is not 1 intruder alarm sensor that can be used in all environments. For example a PIR cannot be used in rooms with fast acting heat sources. Whilst a Dualtec cant be used in close range to glass. I wrote a post detailing how they work and how to avoid common mistakes when choosing a detector technology as well as the manufacturer How Intruder alarm Movement detectors work
  23. You can add a radio expander to this panel via the bus. Then compatible smoke detectors can be added. To use a call point you would need a clean switch model and add external eol resistors. A speech dialler can be directly connected to one of the programmable outputs. But this would not make it a complaint fire alarm. If BS5839 is required you will need to use a compliant fire alarm panel.
  24. Eaton I-on 10-50 Zone Expandable control panel https://www.securitywarehouse.co.uk/catalog/intruder-alarm-equipment-c-36/security-control-panels-c-36_102/110-input-zone-small-c-36_102_101/eaton-ion-1050-zone-expandable-control-panel-p-5752.html Will this work with radio smoke detectors? Is this compatible with manual fire alarm call points? And finally will this need some sort of relay box to work with a speech dialer? Thanks.
  25. Omitting Zones Your system may be programmed so that you can omit individual detectors. Ask your Installer which zones can be omitted. To omit a zone: 1. Key in your access code or present a tag and press X. The display shows: Omit Zone? 2. Press the number of the zone you want to omit (for example, key in 07 to omit zone 7). 3. Press Y. The sounder gives a double beep and the display shows the zone number followed by an "o": Note: Omit Zone? Omit Zone 07o If the display shows a “x” after the zone number then you cannot omit that zone. To omit further zones repeat steps 2 and 3. 4. Press X to finish. To set the system with an omitted zone: 5. Key in your access code (or present a tag) and press a Level key.. 6. The control unit gives an error tone and the display shows (for example): A:Omit Zone 07? 7. Press Y. If necessary, press Y again for each omitted zone shown on the display. (If you wish to escape press X.) After you press Y for the final omitted zone the control unit starts to set.
  26. Hi how do I omit a zone on key a control pad 9651 /9941?
  27. What wireless rx are you using. I assume this is then connected to the panel hard wired?
  • Who's Online   0 Members, 0 Anonymous, 10 Guests (See full list)
