	  Will this fit an accenta g4 alarm panel?Secware_Tech6 replied to secware3's topic in Intruder Alarms yes or Eaton M12 multi sensor smoke and heat detector
	  Would this be a suitable quality replacement for a failed pirSecware_Tech6 replied to secware3's topic in Intruder Alarms yes probably, what sensor are you replacing and in what environment?
	  How do I omit a zone on a Scantronic 9651 with 9941 keypad?Secware_Tech6 replied to secware3's topic in Intruder Alarms Omitting Zones Your system may be programmed so that you can omit individual detectors. Ask your Installer which zones can be omitted. To omit a zone: 1. Key in your access code or present a tag and press X. The display shows: Omit Zone? 2. Press the number of the zone you want to omit (for example, key in 07 to omit zone 7). 3. Press Y. The sounder gives a double beep and the display shows the zone number followed by an "o": Note: Omit Zone? Omit Zone 07o If the display shows a “x” after the zone number then you cannot omit that zone. To omit further zones repeat steps 2 and 3. 4. Press X to finish. To set the system with an omitted zone: 5. Key in your access code (or present a tag) and press a Level key.. 6. The control unit gives an error tone and the display shows (for example): A:Omit Zone 07? 7. Press Y. If necessary, press Y again for each omitted zone shown on the display. (If you wish to escape press X.) After you press Y for the final omitted zone the control unit starts to set.
	  I am looking for a 2 or 3 camera system for continuous recordingSecware_Tech6 replied to secware3's topic in CCTV Hi Solar powered cameras are usually diy type products and not professional grade. There are solar options but due to the size and cost and usually specialised. Plus you will need to run some sort of wifi transmitter as well as the camera. You will also need to consider the time the camera and any ir emitter will have to function during hours of darkeness and low recharge output in the winter,
Forum Statistics3.3k
Who's Online 0 Members, 0 Anonymous, 21 Guests (See full list)- There are no registered users currently online
