can anyone provide list of kit for easy install and use of intruder alarm kit using tel communicator eg Informa speech dialler, key fob set/unset,can these things be used with control panel with onboard keypad if so which one and are they also compatible with each other.thanks jw
thanks alot for last comment I was a little confused about that at first.So then dialler needs to be used in conjunction with RKP of any sort including easy set fob or an onboard keypad or easy set fob...is this correct?
Also will dialler communicate with mobile phones and if so is landline tel socket connection always essential for correct operation of system ?? ...sorry to be a nuisance, many thanks JW
you need a keypad for the alarm for programming etc, the dialler will normally reside adjacent to the panel. Yes once connected to a phone line it can dial landlines, mobiles etc.
