Euro Mini Double Pole Wiring And General
Dorianp
Hi,
Forgive me if this is very obvious, but I am new to wired alarms and just want to confirm in case all goes wrong...
We purchased the Castle Euro Mini alarm from you recently, we are looking at installing it but had a query, if we want to wire more sensors than we have inputs in the unit, can we wire them in parallel  in the same way you would wire the Tamper circuit in double pole wiring? then if so, is there a limit or recommended maximum for sensors and cable lengths etc?
Our other question, due to it's position, we purchased a duplicate genuine alarm box (not a dummy). should these be wired in together to the same terminals or is there another way?
Again apologies is these are very obvious questions but your advice would be appreciated.
Many thanks
its not good practice to do this, it is possible and it will work but in the future fault diagnosis will be impossible. You would wire in series also not parallel.
you need to series the tamper return and ho -ve when using 2 bells but it sounds like the euro mini isnt suitable for  your system. it may not have enough power for the size of your system.
arh ok thanks. I missed off by accident as we don't have it yet, but we were going to add an auto dialler to the unit. Hence running short of that 1 extra input.
Just to confirm, do you mean both wired with a tamper and switch, but 1 box supplied by a separate 12v supply+battery back up?
you need to wire the ho- of the second bell from the tamp return of the first. Or only connect 1 tamper switch.
I'm not entirely sure of how the link works now... do you have any diagrams that show all the connections of the 2?
If I were to have the second bell box with an independent power supply (it would use the ho+ and ho- is that right?) so i'm not sure how that would work
