why does my alarm not arm when I close my door
  1. 1. why does my alarm not arm when I close my door
    • door contact
      0
    • door contact
      0
Hi my home has been fitted with a scantronic 9651 system, it has p.i.rs in all down stairs rooms.
The front and rear doors have surface mounted contacts.
When I set the system and leave via my front door the alarm continues to beep and will not arm once I close the door.
This has happened before and I was advised to replace the door contact which i did, this solved the problem until now!
The same thing has happened again I have checked the contact and everything seems to be OK with no loose wires.
The contact is grade 2 with a small circuit board inside, it also has a small spring tamper mechanism.
Can anyone help?
regards
Steve
