I have inherited an alarm system in my house. One of the detectors is now regularly giving false alarms, and I have searched to see if spiders are the cause but have not found any. So I assume that I need to replace the detector which is a Pyronix Enforcer super 15m range PIR. I understand that these are no longer produced, so can you please recommend a suitable replacement that will be a simple swap over. It has 4 wires going to it, I believe that 1 pair is for tamper detection, and one for the alarm signal.
Many Thanks
Jon
There should be 6 wires , power , alarm , and tamper pairs , unless its eol.Before ordering new , check the voltage at the pir , should be no less than 12vDC.Alternative pirs would be a Colt XS or a Magnum.
