October 12, 201015 yr i`m installing my alarm that i purchased earlier this year. 1. the odyssey 1e, there are three switches inside, is it only the one for the battery to be placed on that i move? 2. i`m wiring to global tamper. can i twist all the power wires together and then insert into power terminals? 3. any zones that i do not use, do i need to use the staple like pieces? any help would be great, thanks...
October 14, 201015 yr 1: Yes . just activate the battery when you have finished the install. 2: the power connections go into the aux power terminals , I usually limit these to 4 , any more and use connector blocks. 3: On the veritas , you can program the zones to off , or not used (zone dissable suite pg.36), but I still place a link in them.
November 11, 201015 yr Author thanks for the reply back. sorry taken so long been on holiday. advice was a great help thanks
