hassanm
    3
Everything posted by hassanm
  1. hi, well i have packed it away.. its going to be swapped on monday! thanks anyway
  2. hi, i took special care when putting the battery in and did do it the correct way i also tried it without the battery and just the mains and it stills smokes! ithanks
  3. Thannks!
  4. hi, recieved my Order today while applying power to the panel and connected the battery smoke started to come out the panel.. so i switched it off and contacted an alarm installer and told me the panel is faulty! while doing this the fuse for the battery burnt out! the battery is fine and just need the panel and keypad changed! thanks! the order number is #19740
  5. hi... should be recieving my alarm from you trammorow and want to take a go at installing it my self.... but looking at the wires my sons layed 8 core instead of six :-\... and than for the internal speaker they did not feed the wire to the control panel instead the fed it to the keypad :-\. what can i do can i use the 8 core wire? and what about the internal speaker... and plus they layed the 8core for everything which is the bell box... PIR,s . Thanks guys by the way the alarm i purchased is ADE Honeywell Accenta Mini Gen4 with LCD Keypad hope that helps thanks!
  6. what is wrong?
