there are 6 pirs and 3 door contacts on the panel, out of 6 pir, one is Eurosec V40DT Dualtec, 2 are Eurosec V40 Quad Onboard Resistors and 3 are Eurosec V40 PIR with onboard resistors. all 3 door contacts are SECWARE SC517/EG Brown, the bell is novaguard 6 and there are 2 keypads in daisy chain. the battery is Enersys 12v 7.0 A/h Battery. also one speaker SECWARE 16 Ohm Internal Speaker is connected.
this problem did appear first time couple of weeks ago(when the log said watchdog reset) when I only had the 6 pir with no door contacts and no battery in the panel and no SECWARE 16 Ohm Internal Speaker and only one keypad connected.I also have a old bell (novaguard 2) which I have connected in the last couple of days instead of nova 6 and the problem is still there.
how would I find day mode current of this panel and the charging voltage?
since the system is hung, I will take the power and battery off and restart it
thanks
