Secware
Moderators
    68
  • Days Won
    16
Secware last won the day on May 31 2018
Secware had the most liked content!
About Secware
  • Birthday 01/01/1
Profile Information
  • Gender
    Not Telling
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
Secware's Achievements
36
  1. I want to cennect to my Texecom Premier Elite 24 using Wintex on a laptop connected to the household LAN. Do I need the ComIP at around £107.79? Is the Connect Samrtcom Ethernet & WiFi CEL-0001 at £76.79 still available and would it be an alternative.
  2. Well, the Honeywell ADE Informa speech dialler I bought is to replace the current AD2000 speech dialler that is not working any longer. The speech dialler is to be connected to an Ademco 4204 relais module (with 4 relais) which in turn is getting its pulses from a Honeywell Vista 50P alarm system. So, basically, when there is an alarm in one of the 3 partitions I have in the alarm system (the Vista 50P), this triggers one of the relais in the Ademco 4204 which in turn triggers the speech dialler which then calls the phone of the home owner. The problem is that the current AD2000 speech dialler is connected to the Ademco 4204 relais with two wires each while the Honeywell ADE Informa which I bought from you only has one port for one wire per partition. The instruction manual which is provided with the ADE Informa is too short and does not provide enough detail to know how I am to connect the two wires from the Ademco 4204 relais to the Honeywell ADE Informa.
  3. Will Fike Sita ASD Detector with Sounder work with ADE Honeywell Accenta Mini Gen4 with LCD Keypad 8SP399A
  4. I am replacing old ones of these. On the existing Optex EX-35R units is a sticker 869Mhz When I get these new ones, howh do I 'pair' it to the existing old Tunstall control unit, or how do I set the frequency to 869Mhz? Cheers in advance.
  5. Will these Optex Battery Powered 4 Channel Synchro Twin 30m Active Beam work with The new Visonic powermaster GTX kit https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/active-beams-c-36_142/optex-battery-powered-4-channel-synchro-twin-30m-active-beam-p-3371.html
  6. Hi, We are looking for a UL approved device and the Honeywell unit does not have that, please see my full specification below Our application calls for motion detection within a space (floor area of max 6mx4m) mounted at a height of nominally 2.5 – 3m with angle and rotational adjustment to optimise operation. Hence the request for the Bosch mounting bracket. We only require a single relay contact for detection of motion. (switching duty 24Vdc at < 10mA) PIR supply 24vdc operation preferred if possible, if not 12Vdc operation is OK. This application is for the US market and UL approval is specified. Hence the initial request for the Bosch PIR. Tamper facility is not necessary, however if fitted is OK. Pet facility is not necessary. However if fitted is OK. Please can you advise if you can supply a PIR to suit from your available stock. Many thanks your assistance with this.
  7. That’s no problem and I’m happy to also replace the control box as required. I have looked at the installation manual for the Accenta and some of the screw comnection are labelled differently to my existing 800L unit. Please would you advise which connnections on the Accenta control unit, correspond to the following (existing) connections on my 800L: -R S ST Many thanks,
  8. i've purchased a Honewell 8EP416-EU to replace the RCP on my C&K Securit 800L. Please would you confirm which connections (COMMS and SOUND) correspond to C and D on the old Securit RCP? Thank you.
  9. Hi The Dycon Mescom Short Message Communicator D6000 is now obsolete, is there an alternative product which I could instead of this? Thanks
  10. would the Siemens IMKW6-10 wireless contact work on a Europlex signet 200 alarm panel.?
  11. Could you please tell me how I can pick the updates for the newer panel with the new display panel coming up to date
  12. Would it be possible to use a Voltek 1803 alongside a Takex PR11BE Beam?
  13. we are searching for Flush mount type magnetic contact EN 50131-2-6 compliant, Grade 3 type do you have any?
  14. I'm looking at buying the dualcom complete with 1 year monitoring but I'm just wondering how that works who it's monitored with etc Do you guys do all the applications etc as I'm not a registered installer with them Or do they just liase with me direct? It's just to figure out who the customer would be. Me or the end user. Many thanks
  15. Is this the only Guardall concentrator that you stock and if so is it compatible with the PX range of control panels?
