Thank you.
	We do require prox key pad and it has to work with https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/intruder-alarm-ancillaries-c-36_46/ade-honeywell-easy-set-fobs-tags-5pk-p-2097.html as we have many alarms that already use that type of fob/tag, can you kindly confirm that the galaxy works with that?
	Also it appears that the Galaxy key pad with prox is £168.41. That is top money for a key pad (we need 2!)
	Do you have any alternative suggestions? Perhaps a control panel that is setup already with a remote key fob (incidentally we only require the following to be wired, 2 pir sensors, 2 key pads, an internal sounder and an exterior bell box, if that helps?). Must be able to use the above style prox key fob/tag.
	Thank you, Richard
