Yesterday, I tried to plug the 8XE internal zone expander on my Premier 24, but it failed: the flash programming connector is longer than the expander support pillars. So it is not possible to clip the pillars.
I can make photos if you need to better understand the issue.
Please advise. Thanks!
(I opened ticket # 24795 for that, but the answer was to ask on the support forum).
Hi,
I'd like to upgrade my premier 24 to a premier 48. I already have the metal case. Is it possible to buy a premier 48 without
the metal case (assuming both metal cases are compatible) ?
Thanks.
I just bought an AMDT and I'd like to understand the purpose of the SET wire.
What is the Alert/Set mode ?
Should it be left unconnected (and be in the standby mode) ?
BTW, what is its current drain ?
Thanks.
