Tomas74
Everything posted by Tomas74
  1. You can see the connector type here. It's a Swedish website but maybe you van figure it out
  2. Thanks for your help. The GSM module seem to work just fine! Best regards, Tomas
  3. I just received this answer from Honeywell technical support: "The cabling is as follows on the GSM connector pins on the panel, : +12 / 0 / D / C from left to right. The cable is straight, so on the GSM module the order is the same. Make sure you position the module correctly." I find this all a bit confusing. Does anyone have a photo of the original cable? What would happen if the cable is connected wrongly, will the GSM module be destroyed? I have attached a photo of my homemade cable.
  4. Hi, I have a problem with a missing cable. It is the cable between the panel and the GPS/GPRS module. It seems impossible to buy the cable in Sweden. So I have purchased components to make my own cable. But when I looked in the (Swedish) instruction manual it looks like the wires are connected cross-over. (see attached files) Can someone please confirm how the wires should be connected? straight (Example 1 in the attached file) or crossed (Example 2 in the attached file)??
  5. That sounds promising that you haven't had any false alarms yet. But what kind of movement sensors do you have in your home, PIR or dual technology and are they "Pet tolerant"?
  6. Hi, Will a Robot vacuum cleaner trigger the alarm? I'm thinking about buying a robot vacuum cleaner but I'm worried that the vacuum cleaner will set off the alarm system. What can I do to avoid false alarms. Is it best to buy pet tolerant movement detectors with dual technology or is it enough with PIR? Or will the alarm go off no matter what kind of movement detectors I use? Best regards Tomas
  7. Will it be possible to install all the following equipment internally in the same panel Galaxy Flex 50 (C006-E2-K04): Galaxy Flex GSM/GPRS Module (A081-00-01) Galaxy Flex Direct mount RF Portal (A073-00-01) Ethernet Module IB (A083-00-01) Yuasa Battery 12 V 7Ah Or do I have to choose between eighter GSM/GPRS or the Ethernet Module? Or is it only unnecessary to have both of them? The most important for me is to be able to send messages to several phones if the alarm is triggered.
