Hi!
Bought a Visonic Powermax+ alarm from you and have run into some problems regarding master installer code and installer code. The problems shows on both the central unit and the keypad unit.
When I installed the alarm, I (of course) changed the default codes to my own. However, as far as I can remember I only changed 2 codes where off one being the user code and the other one either the master installer or the installer code. Now I can't seem to access the alarm using the other alternative of installer codes. I would be glad if you could give me some hints to where I've gone wrong.
The setting and fault behavior right now are as follows:
1. When first changing the installer code, I acted as written in the manual's figure 4.1a. However I can't seem to be able to change the master installer code as shown in figure 4.1c - only by using the installer code. The only option I get are how to change installer code - not the master installer code.
2. When running the setup according to figure 4.5, I can access all sub-levels except 35-38. I can access the levels listed in the note indicating that the code I entered are the master installer code. This is strange to me since, as written previous, I seem to be using the installer code.
3. When trying to clear the event log, I can't reach that level - only "list of event". In the text in figure 7 it indicates that the "clear event log"-level is only accessible through entering the "installer code". This seems ok if it hadn't been for my inability to access the master installer code as written i para 1 when it according to para 2 seems to be the master installer code that I'm really using.
4. When trying to access the supervision level in my keypad, I can't use any installer code - only my user code, which don't give me access to the real supervision levels as written in figure 8 in the manual for the MKP-150/151.
None of the default codes work (all according to plan), so either there wasn't more than a default user and one either installer or master installer code.
* Can you help me figure out if I'm using a master installer code or an installer code from my description above about how my alarm acts?
* My keypad don't respond to either my installer/master installer code - why?
