mcfield
Everything posted by mcfield
  1. Right, from my weekend investigations. All the fuses on the panal are Ok. When the battery is connected the alarm will power up although still no power light on the panal or the RKP. With with the mains connected without the battery the panal is just dead. I've tested the supply and power is getting to the panal so i assume that its power handling on the panal that the problem, is this easy to fix ?
  2. and one more stupid question.... do i connect up the battery before or after the main supply... If i do it before, the battery has some residual power it in so sets the system off....
  3. so remove all the wires, link the tampers (with wire or the little metal things it came with) check fuses and wire the panal in and hope it works. If i've blown the aux how do i fix that ?
  4. Hi, I'm after some advice on my Accenta G4 system, as with most good DIY project a purchased it a few months ago and only reently got round to fitting it (a wedding got in the way). Anyway i've installed it and powered the system up and two issues occur. 1) There is no power on light on the system or the key pad (or any light on any of the sensors). 2) Although the key pad (and alarm) operates (i'm assuming from the battery), when i enter the security code on the kep pad it says tamper lockout. Now i can accept that there may be a tamper fault somewhere but i wondering first whether its all related to the power problem and whether there is perhaps a fault on the board ! Would welcome any advice. Thanks Mark
