dannywilko
About dannywilko
  • Birthday 01/01/1
Profile Information
  • Gender
    Not Telling
dannywilko's Achievements
  1. ok, i see now, if i was to want beam detectors do you stock any which would be compatable with the texecom veritas r8
  2. thats good, thankyou, do i need 1 or 2 devices - 1 at each end? im looking to install it to the side of my garden.
  3. Hi all, im just wondering if the, Texecom Prestige External TD Outdoor Motion Sensor, is compatable with the texecom veritas r8 system, if so how is it connected and can you use the chime facility? thanks daniel
  4. dannywilko
    4ch h.264 dvr
    i got a new dvr (4 ch h.264) and silverline cameras, i have connected all the wires etc.. but the dvr wont display on a monitor or tv, what could be the problem? thanks
  5. Am i right in thinking the internal sounder should sound along with the external when the alarm is triggerd? since mine doesnt, all it seems to do is the chime facility. daniel
  6. Problem still on going. What do you reccommend? daniel
  7. Hi, thanks for your support, I have the engineers code, I entered the engineers mode to sort out my door contact on z3 daniel
  8. it sounds like the nee-naw daniel
  9. Yes everything else seems okay - lets start with the programming Thank you
  10. i have looped out z2 and alarm doesnt trigger, so maybe programming error, if i reset the panel by doing the 07 command, would you please be able to give me step by step instructions on programming the system. heres how it is wired z1 - Living Room - pir z2 - kitchen - pir z3 - downstairs passage - door contact only z4 - landing - pir z5 - small bedroom - pir z6 - marster bedroom - pir (i previously had z3 entry/exit and rest guard) i hope i can get this sorted has have 2 young kids and want to make it safer for them thank you daniel
  11. I have disconnected every wire and re wired it same as manual and same as when the alarm was working, Im still having this problem. ? thanx daniel
  12. i programed zone 2 to guard, how would i rectify this problem? thanx daniel
  13. Has it just recently started doing this? You havent got into engineer mode and accidentally adjusted any settings? Can you tell us whether a tamper light is illuminated on the keypad? There may be 2 things: 1) Z2 may be on 24 hour intruder 2) There is a tamper condition at the panel. Also is the panel generating a full alarm condition with your outside bells and inside sounder ringing? If not then let us know. It may just be chime, that can be switched on very easily and accidentally what i did was open the panel - and disconnected the door contact on zone 3 from the aux ports, because i was told on here the contact doesnt require power. i put it all back together - now when i go in the kitchen it fires full alarm condition and indicates zone 2 on the panel - the tamper light is on also on but i think this is because i have now got the panel lid off due to trying to sort this out. also im no expert as you can prob tell, but when the alarm is going off the sounds seem different -deffinately full alarm not chime tho - just the noise seems different. hope you can help me sort this out daniel
  14. My house alarm (veritas r8) keeps going off while unset. i walk around my house then go in to zone 2 (kitchen)where i have a PIR, the alarm goes off while unset, the keypad lights up indicating zone2 how do i stop this? thanx Daniel
  15. Im looking to purchase 2 camera kits - Silverline 4 IR External Camera Kit.
